RCU Forums - View Single Post - Spiraling slipstream & pattern aircraft design
Old 01-02-2006 | 09:41 PM
  #66
mesae's Avatar
mesae
Default RE: Spiraling slipstream & pattern aircraft design
ORIGINAL: 8178
This may be a rhetorical question but have you ever noticed that the oil streaks on your RC aircraft always flow exactly in a straight line from the nose to the tail?
Good point. The effect of spiral slipstream alone is small but still significant. What power setting are you using prior to landing? One that allows the slipstream to straighten out, thereby straightening the oil streaks. Also, the oil is in the boundary layer, which has a very low velocity relative to the fuselage surface, and does not necessarily reflect the behavior of the air 1/2" or 1" away from the fuselage. Still, a very good observation, and worth considering.
