RE: 3W STARTING PROBLEM
Man oh man, just temporarily open your low needle a turn and then try and start the motor. If it's been sitting for awhile then this is the easiest thing to try unless you like pulling reeds, carbs, tanks, clunks and on and on. If the motor was running fine before it will run fine again.
