RCU Forums - View Single Post - Binding pull-pull system NEED HELP
Old 01-03-2006 | 12:31 PM
Darrinc
Default RE: Binding pull-pull system NEED HELP
That is normal. Sam Malone makes some very nice offset arms btw.
ORIGINAL: shag555
Hey... I didn't know you needed an offset arm to counter a control horn that was offset from the hinges! I have a question for you guys then... In my setup on an extra 260, when the rudder is thrown to either side, I get slack in the opposite cable. When the rudder is in a neutral position, both are taught. Is this my problem, maybe it's the horn / arm not equal??? This plane is grounded till spring, so there's no worry about crashing... It flies well now, but that slack worries me.
Thanks a million,
MPB
