ORIGINAL: Zelatio
ORIGINAL: ckangaroo70
... because unless you have a new alienware computer, the G3 is going to run like garbage if you try to use any of the features, unless you turn every single setting down to the minimum...
I'm not sure where you came up with that. I have a 2 year old Dell laptop with a 32 Mb Ati Video card, P4 2.4 Ghz Processor, and 256 RAM. It runs G3 like a champ, I can have all settings to medium or higher and still have 40-50 FPS.
I don't doubt yours does fine, but I was giving some recommendations IMO to try to get the G3 comparible to G2 and within the 75 fps range, and still enjoy some of the features like the moving trees, smoke, etc. I do realize that there are people running the G3 on less of a system than I recommended, I was basically just saying I would not recomend somebody to go out and buy it unless they were at least running what I recommended even though smaller stuff may indeed run it ok. I just would not want to be the one to tell that there system would for sure run it good!
