RCU Forums - View Single Post - B&D Retract Dimensions
Old 01-03-2006 | 03:03 PM
RCer
Default RE: B&D Retract Dimensions
Here are some measurements:
I don't know the names of the gear parts. I imagine the gear consisting of a mounting plate with a cylinder box mount to it (event though it is one plastic piece).
Mounting plate:
height (parallel with cylinder): 47,2 mm
width: 44,4 mm
thickness: 3,1 mm
Cylinder box:
width: 19,0 mm
Where the box rests on the plate its rounded so the mounting rails have to be futher apart than 19 mm. I have mine 25,5mm apart.
What other measurements do you need?
Regards
RCer.
