RCU Forums - View Single Post - Funtana 40 engine Q need your wisdom
Old 01-03-2006 | 06:54 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Funtana 40 engine Q need your wisdom
Of the two engines you mentioned the 61 is the only choice. If your not worried about the 3D abilities of the plane the 61 is a good choice. Set the throws low and balance it in the range and you will be fine.
David
