RCU Forums - View Single Post - Getting over the right stick break
Old 01-04-2006 | 10:51 AM
2slow2matter
Default RE: Getting over the right stick break
I'm not sure about futaba, but on most radios (and I suspect futaba is no different), the stick tension is adjustable.
Edit:
As is stick height, which may also be causing you some grief. If the stick is too tall, then you can have problems at neutral (assuming you are a thumb's only flyer) because that is where the stick will be "tallest." Try shortening your stick height, and, if that fails, try alleviating some of the stick tension.
