RCU Forums - View Single Post - Binding pull-pull system NEED HELP
Old 01-04-2006 | 06:02 PM
cbk07
My Feedback: (64)
Default RE: Binding pull-pull system NEED HELP
ORIGINAL: Darrinc
That is normal. Sam Malone makes some very nice offset arms btw.
ORIGINAL: shag555
Hey... I didn't know you needed an offset arm to counter a control horn that was offset from the hinges! I have a question for you guys then... In my setup on an extra 260, when the rudder is thrown to either side, I get slack in the opposite cable. When the rudder is in a neutral position, both are taught. Is this my problem, maybe it's the horn / arm not equal??? This plane is grounded till spring, so there's no worry about crashing... It flies well now, but that slack worries me.
Thanks a million,
MPB
Hey, isn't he the bartender on Cheers? I think you mean Sam Monteleone http://www.wideopenwest.com/~surelink/
He is good, but usually very slow. Try Scott at SWB. He is very knowledgeable, has top notch products and usually ships same day http://www.swbmfg.com/
Of course, if you are as poor as Darrinc, you could make one out of scrap aluminum or carbon fiber like I did. fortunately for me, I can afford to buy the other stuff, but needed a custom offset to keep the tension the same throughout the throw and did not want to wait for a custom one to be made. (I know, I know, I am an idiot because I use regulators and 2 Rx's, but I like the pretty blue color and needed something to waste my money on)
ID:	381066   Click image for larger version
