RCU Forums - View Single Post - Ream for BME 100
Old 11-19-2002 | 09:10 PM
d4a2n0k
Default Ream for BME 100
I am going through the same problems with my BME 50. I have not found a reamer large enough (7/16") that will do it. This website http://www.bennettbuilt.com/ has a stepped drill bit in the correct size for around 15 bucks. It has a 1/4" step in it so it guides itself through the stock hole of the prop. Make sure you use a drill press!
Good Luck.
