RE: Batshare Question
Okay I've read through these threads and I think I've got it.
This will be for a 33% size model with three big digital servos for the tailfeathers, four high speed coreless analogs in the wings, and two standard servos for throttle and choke.
Dual 2800 Li-Ions with dual switches run from switch, to BatShare, to regulators, to receiver there by avoiding the .5 volt drop associated with the BatShare?
This may be a dumb question but I posted on Futaba's forum and don't have an answer yet. I'm assuming you can plug the two power leads from the Li-Ion regulators into a R149DP receiver if two slots are available?
And the other question for a buddy who's got a BatShare but couldn't figure out the two output lead thing. He's got two NiMh's with separate switches to the BatShare and only a single output of the two BatShare leads needs to be hooked to the receiver unless you want the higher amperage capability?
Thanks in advance!
