RCU Forums - View Single Post - Reciever pack for the 3d Mayhem?
Old 01-05-2006 | 02:15 PM
STG's Avatar
STG
My Feedback: (26)
Default RE: Reciever pack for the 3d Mayhem?
ORIGINAL: bohemus
Just wondering whether this particular pack would be of use as a reciever battery. The price seems pretty reasonable and 1400mah with 20amp discharge!...seems like alot....would this be enough for high torgue 100 oz+ on 4.8v servos (6 of them) ....what kind of current draw would you have with the high torque servos?
#1414S 4.8v 1400mah NiMH 4 cell AA Stick Pack
Cell: KAN 1400mah AA
Discharge rate: 20amps
Wire: 22ga Rx, 14/16ga on larger connectors
Size; L 3.84" x W 1.12" x H .56".
Weight; 3.8oz.
Here is the link...
http://www.onlybatterypacks.com/show...ItemID=10354.6
[link=http://www.onlybatterypacks.com/showitem.asp?ItemID=10354.6]batterypacks[/link]
Not sure if it has standard connectors or not? Otherwise the pack is fine. The discharge rate is much higher than you need for a receiver battery.
