Engine Decision
if you go with the os 50 you'll need the uniball clutch system and you may need to have steel pins installed in the fan hub by m/a. mine tore out the stock pins after 6 tanks because of all the power. i've heard some others haven't had the same problem, but be prepared. it makes an x-cell 30 a very powerful machine.
