RCU Forums - View Single Post - SuperCap CG Problem
Old 01-05-2006 | 09:47 PM
Ksubram
Default RE: SuperCap CG Problem
SuperKaos,
Actually I forgot to mention -- while flying mine for about 6mins or so the motor cuts outs in flight. This has happened every time I fly. I land it and then after about 10secs it flies again. I called Hacker about this problem and they think the motor could be shorting out. They asked me to return it for a new replacement. So I can't fly for a few days.
Also your problem with tip stall is probably due to LATERAL Balance. I have very small tiny lead weight at the tip of my left wing. I have found that when a plane is laterally balanced, landing is aways a breeze. In fact you can float the plane in at landing. The SuperCap actually slows to a crawl while landing. Landing is a lot of fun. Try balancing yours and I bet you that is the problem.
Will keep you posted.
Kris
