JPMacG,
Very nice! I noticed in your pictures that there is not an 1/8" balsa strip on yor wing struts. Is this on purpose? I have read on a review that this area when used with the strips became very hard to cover so the person doing the review left them off. Also, the plans called for balsa strips to be cut and glued to enclose the sides of the cockpit. The way I am looking at the pictures appears that these strips are missing. I'm not cutting apart your work, I am just curious because if you found a better way of doing some things then it would be great to know. Otherwise, your build looks awesome and I can only hope mine turns out just as good.
Keep up the good work.
Tim
