ORIGINAL: BrianKoch
The other lead has a female crimp-able connector ready for another wire.
Is this where I will connect the kill switch?
Thanks in advance for the help!
Brian
Yes, one wire from your switch will go to the female "crimp-able" connector, and then you will ground the other wire from the switch to the engine. Any convient screw or screw hole will do. With the switch in the
ON position, you will shunt the coils to ground and stop/kill the engine.
> Jim
