RCU Forums - View Single Post - Roll Coupling
Old 01-07-2006 | 08:40 AM
rmh's Avatar
rmh
Default RE: Roll Coupling
The rudder does not drop the wing --
roll couple -basically is a setup where the rudder produces a force which rolls the the plane --as it yaws the plane
this can be in the same direction as the rudder is directed OR the roll may be in opposite direction.
The way the plane is layed out determines this.
high wing planes such as Piper Cub tend to roll in the direction of the rudder application.
low wing planes with no dihedral tend to roll in the other direction (right rudder=left roll)
There are many methods of changing the direction and amount of roll couple .
Basically - the force of the rudder is overcoming the stability of the wing
So the wing needs more (or less) dihedral to counter this force (from the rudder) -which is acting as a rolling force as well as a force which yaws the plane.
Maybe you want some lengthy tech explaination -- but this is the short version.
