RCU Forums - View Single Post - P60 - Acceleration low - won't start
Old 01-07-2006 | 03:05 PM
Jim Cattanach's Avatar
Jim Cattanach
Default RE: P60 - Acceleration low - won't start
If the noise you are hearing is a crackling noise from the turbine, it is unburnt fuel boiling away.
Check all the settings of the turbine with your GSU to see they are ok. I had an ECU that became corrupted & the turbine would not start.
Clean all the fuel filters. Check the vent pipe to your fuel tank is not blocked. Disconnect the fuel supply to the turbine & run the pump manually & check the fuel flow.
Regards
