RCU Forums - View Single Post - Guillow's Spitfire Build
Old 01-07-2006 | 04:50 PM
Phlip's Avatar
Phlip
Default RE: Guillow's Spitfire Build
After getting the right wing put together, I decided to get the aileron designed and built before going on with the left wing. I could get pretty close to the scale aileron outlines. just a touch larger, and route my torque rods as you see in the photo.
Then I cut the TE with a razor saw, and the ribs with a razor blade. Then I fit a piece of 1/4 square balsa which will accept the Robart hinge points.
Finally I used the cut off TE and ribs to make up the aileron.
ID:	382861   Click image for larger version
ID:	382862   Click image for larger version
