RE: How much vibration?
Vibration needs to be eliminated as best as possible. Check all your mounting screws for tightness. Pack your fuel tank with foam so the fuel does not foam up. If your control surfaces are moving, something is loose or your radio needs repairing. Another cause of vibration is a bad prop. Good Luck, Dave
