RE: engine idle down problem
I think the high speed/low speed needles are out af adjustment. Possibly the main needle is a tad lean, whilst the low speed needle is set correctly or is slightly rich.
Or... it could be a simple throttle linkage problem, which does not allow the carb to close fast enough once you come off the gas. I'd check that also (you should be able to do that w/out the engine running).
