RCU Forums - View Single Post - Flip 3D (build/set-up tips)
Old 12-02-2002 | 07:01 PM
YNOT's Avatar
YNOT
Default Flip
Got mine, well got one thanks to Ulf, A.K.A Texas 3D. Thanks!!!
Yea, the metal hinges, gotta go.
It has no vertical fin, only a rudder, I really like that.
A 91 or 100 stroker is way out of line. I don't care how much prop will clear, those motors would ruin this plane. If it was a little bit bigger like a Prozac or a Show Flyer is would work. YS 63 or a Satio 72 would be perfect. I'm going with the OS 50 FS-H. Yea, the heli version. I will never put a remote needle motor on a 3D plane again.
CPLR took the Madness and made it better. I have put the parts next to the Madness and he just tweeked it in all the right areas. Larger surfaces everywhere, moved the motor line up to swing a bigger prop, straight leading edge wing, shorter nose and made it so the tank can be closer to the CG.
The Flip should be more durable than the Madness. It is built stronger however i don't think it will be heavier by much.
The plastic control horns are nice. They don't bend like the nylon ones do.
I'm going to use a piece of carbon fiber on the horizonal stab instead of the flyn wires.
Will post more when I get some of it built.
