RCU Forums - View Single Post - Flip 3D (build/set-up tips)
Old 12-13-2002 | 02:20 PM
WwpIII
Default elevators torque rod
so tony how did the elvevator torque rod work for you...are you getting much flex between the two halfs using it...i finally have received all my orders from various places....going with the rudder servo (pull-pull) mounted in the cockpit floor, just a little reinforcement needed...i think i will order some of that CF strip you used and look at using it on the stab....wish i could find a CF landing gear for this....i am having problems finding one the correct width (front to back) for mounting it, i need one about 1 inch wide.....
