crashing
By the By, I forgot to mention that if you have a piece longer than your scanner will accept such as one piece fuse sides, draw match lines on the plans and scan the piece in sections. When you print them out, simply line up the match lines and tape them together. You need to be careful about aligning the match lines, but you can reproduce parts perfectly every time.
