RE: Elevator with compensator stability
I would add another thing.
I think the issue depends on counterbalance surface - or the ratio between surface area and counterbalance area. I say this because that weird behaviour happened to me even with a .40 3D plane, which I tried today. It had the same problem, and the counterbalance area of the elevator was quite big with respect to elevator area...
So with a better mechanical advantage the problem might be reduced?
