RE: split elevator problem
At this point , I have a full interior in the plane so the servo in the fuse will be some work and th elevator is totally glued in .
I may have a simple fix .
The rear fuse is solid wood .
I can drill a curved arch(similar to the maximum travel of the Elevator) in the rear fuse at the tips of the rear elevator .
Then expozy a small carbon fiber rod attaching both ends of the elevator and ensuring they are 100% level prior to adhesion .The rod would travel in the drilled out arch with the movement of the elevator . This should be able to hold both ends even and give good solid even control .
What do you guys this about that ? [X(]
