RCU Forums - View Single Post - .40 vs .46 why do the shafts look the same size?
Old 01-08-2006 | 09:27 PM
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: .40 vs .46 why do the shafts look the same size?
A .46 is basically a .40 size engine or case thats been bored out for larger piston. When it comes to Airplanes, weight is everything. So it makes sense to try and get as much power out of a particular size engine without having to create much additional weight! For example: If you set a O.S .40 sf next to a O.S .46 sf, the physical appearance and size are the same. Its whats inside that makes them different. Same goes for the GMS .40 and GMS .46 etc. etc. etc. etc.
