RCU Forums - View Single Post - Walkera 22E Lets Talk
Old 01-09-2006 | 02:11 AM
jdh_nz
Default RE: Walkera 22E Lets Talk
You can see the top of the bolt I've inserted just to the left of the stabilizer rod connection. All I did was get a 2mm bolt, drill a 1.5mm hole where the plastic welded connection use to be and screwed it in tight, then back off about half a turn. There's no friction with this, and to balance the head I did the same thing on the other side. This has worked perfectly so far.
