RCU Forums - View Single Post - ct4-s hinge pin problem i caught
Old 01-09-2006 | 04:34 AM
Steven Stewart
Default RE: ct4-s hinge pin problem i caught
theres a set screw on the bulkhead to prevent the pin from coming out but since its threaded into plastic it doesnt have much holding force. You can put a little notch in the hing pin using a dremel so the set screw has something to catch on and it will prevent it from sliding out.
