RE: CRRC GF45i
heyhey all
houston...we have problem. i had everything all sorted...so i thought. i did a radio range test with the engine running...guess what.... it started glitching all over the place like mad. i did a few more tests and found the battery and switch harness was causing the interferrence. ive since moved things around a little and will re-test again soon.
the engine is still performing great on 25:1 fuel. will mix up a batch of 40:1 synthetic once the mineral oil batch is used. im using a bmr6a plug and a bolly 20x8 carbon prop.
cheers
craig
