RCU Forums - View Single Post - Jersey Modeler Pump-Split tanks ?
Old 01-09-2006 | 09:21 AM
Meesh's Avatar
Meesh
My Feedback: (135)
Default RE: Jersey Modeler Pump-Split tanks ?
Hi Mike,
Are you filling into the header tank and is the brass tubing going from the header to the main tank small? If it is, try installing a larger tube. I found that the main tank on my Boomerang would swell when the piggyback tank I put on top of it was fliing because of the restrictive small tube connecting them. You could also try running it on a 6V pack.
Bob
