RCU Forums - View Single Post - Jersey Modeler Pump-Split tanks ?
Old 01-09-2006 | 10:33 AM
joeflyer
My Feedback: (49)
Default RE: Jersey Modeler Pump-Split tanks ?
If your fuel tank is expanding/contracting during fueling/defueling it's because your vent is too restrictive for what your pump system is delivering. There are several things you can do to prevent or minimize this:
- Go with larger diameter tubes and lines on your tank vent and between tanks.
- Put a restrictor in line on your pump system or go with smaller diameter lines to reduce its flow.
- Reduce the voltage on your pump system.
Since I have one main tank plus a UAT I fill directly into the main tank.
Joe
