RCU Forums - View Single Post - need help finding
Old 01-09-2006 | 03:05 PM
Flyboy Dave's Avatar
Flyboy Dave
My Feedback: (21)
Default RE: need help finding
ORIGINAL: BasinBum
Come on Dave, we both know a 7amp/hour flight box battery is a Gelcell. Also,
while the amp/hour rating does determine the charge rate it doesn't necassarily
determine the charge time.
Yo, BB....you need to study-up. The amp/hr rating for a battery gives the
dischage rate, or "power" of the battery. For example, a 7 a/h battery will deliver
1 amp for 7 hours....that is the batteries rating. A good guideline for charging the
battery with out overheating it (and damage) is to use the a/h rating for charging.
BTW, I learned this technique for battery charging at the Yamaha factory training
school in 1970, and it has worked perfectly for my lifetime.
If you have a better idea on rating or charging batteries, won't you spring it on
the World post haste ?
The "flight box battery" in question is most likely a "sealed lead acid type", not a
more expensive gel cell....although it could be a gel cell, but I doubt it.
See this:
http://www.zbattery.com/zbattery/ub1270.html
....this is probably what he has.
Here's a battery factoid you might want to store in memory. Lead and wet/acid
batteries....as well as gel cell batteries contain acid. The only difference is the acid
is in a gelled form, so it is safer and wont spill. Sealed lead and wet acid batteries
look like some gel cells.
However , the a/h hour ratings for them are the same, as well as the discharge and
charging rates.
FBD.
