RE: Pay It Forward Build Thread!! Sig LT-40 build
If you are only using a single cover, then cover each wing half in 2 pieces. Start with the bottom first. Then apply the top piece, allowing the leading edge to wrap all thw way over the curve of the leading edge. There should be no exposed "raw" edges facing the front of the plane. I'm sure Ken will illustrate this thoroughly when he gets to the covering.
