RCU Forums - View Single Post - RichModels Works LTC ARF's
Old 01-09-2006 | 04:11 PM
  #68
Crazy4Flight's Avatar
Crazy4Flight
My Feedback: (540)
Default RE: RichModels Works LTC ARF's
ORIGINAL: jmupilot
Nice looking LongEZ. Did you have the prop on backwards? Best way to tell is that the curved surface goes forward. I am using APC props so cant judge by the writing on the prop...............Pete
Pete,
You need to buy a "Pusher Prop" It the prop is turning the "wrong way" with the engine turned around. Puting the prop on backwards won't work very well do the the curve of the pitch in the prop.
The other solution to to using a "tractor" prop is to buy a Counter Rotating Crankshaft If it is made for you engine.
