RE: ANOTHER RADIO AND SERVO QUESTION
Tigerdude 426, depending on what radio you have, the travel adjust of your servos may be listed under different names, like tarvel adjust , endpoint adjust or adjustable travel volume. This function will be found in the computer programming function of your radio. So it would help if you can find out the name of your radio, so we can then help you to programme it without guessing is it this or that. Second answer is radio ON, aircraft ON, then Aircraft OFF, radio OFF.
