RCU Forums - View Single Post - DIFF and SHOCK oils for Genesis
Old 01-10-2006 | 01:14 PM
Raptor_67
Default RE: DIFF and SHOCK oils for Genesis
ORIGINAL: JPKII
After reading some of the race setups I decided to go with 10 F, Locked C, and 30 R. I should have it running by tonight so I'll see the results pretty quickly. My LHS has open nitro practive tonight so after I get everything set up I may take it down for a spin. I am suspecting that the truck will push thru the corners with this but we'll see.
Thanks. I look forward to your results.
Starting to realise that maybe a lighter oil in the rear would be a good idea.
Tried to open my Centre diff today. Damn screws locked up so tight that I could not remove one on each side. They are now stuffed. Not sure how I'm going to get em out. still, spose I only really need to take 2 out (one on each side) and drain/fill it that way.
Would 50K effectively lock the center diff, or would I have to go to 100K to effectlively lock the centre diff? (keeping in mind that I cant open the damn thing to put the locker in there)
Thanks...
