ORIGINAL: KidEpoxy
I've heard setting some out trust in the engines helps to pull against the forces pulling it to turn toward the out engine. I'm looking at making a 049 twin pusher, and have 3deg out thrustlines to help keep it going straight on one eng. Think 3 is enough for these narrow engines to push it straight?
Am I seeing this right?
With a twin pusher, shouldn't you set INthrust with this setup?
or is there a rule about setting the thrust line in direct line to the planes' CG?
sorry if these are dumb questions.....
