RCU Forums - View Single Post - Cox Reed Valve FAQ
Old 01-11-2006 | 01:41 AM
burtcs
Default RE: Cox Reed Valve FAQ
While I have been somewhat verbose, the following is a photo collection of popular accessories (gotta have those). While alot of this stuff can't be ordered online, it can be found at swap meets or eBowow. You may have to pound on your buddies at the R/C field, that sort of thing.
Photo 1 is a Cox Pee Wee with a Cox muffler (yes these do work) along with a KK 020 back plate and needle valve.
Photo 2 is the same engine one the front of some kind of air plane with some kind of radio in it (until it's fixed it has a range of about ten feet.
Photo 3 is a Cox throttle ring and KK black plate on a certain engine.
and finally
Photo 4 is is of very good needle valves for Tee Dees. These were made by KK except the Blue one which is an Ace unit.
So, for your viewing pleasure:
Regards - Steve B.
ID:	385380   Click image for larger version
ID:	385381   Click image for larger version
ID:	385382   Click image for larger version
