RE: Spinning the Prop Wrong Way???
Experienced pilots start glow engines by "bump starting" in clockwise direction.
his will not harm an engine, and saves fingers which are well out of harm's way when the engine decides to fire.
Bump starting of gas engines is not an option, because of the ignition timing controlled firing.
On some systems, you won't even get a spark that way.
