RCU Forums - View Single Post - align ESC HELP!!!!!!!!!!!!
Old 01-12-2006 | 02:13 AM
cptsnoopy
Default RE: align ESC HELP!!!!!!!!!!!!
if it throttles up when you bring the left stick down from full throttle then your throttle channel on the tx is reversed. fix that and try again. If after you reverse the throttle channel, you find that you cannot get the esc to arm when you plug in the battery with the throttle and trim all the way down, then you will need to adjust your subtrim lower. (that is if your tx has the capability) note: please be careful!
