RE: Does anyone have a variable pitch prop ?
An ideal approach to adding excess spinning mass while simultaneously introducing new points of failure potential! Trying to optimize an aerobatic model with an adjustable pitch prop is not likely to be very productive, even if you can rely on the blades not flying off the hub. You're going to be stuck with one vendors idea of what a good blade design is, right? It might be better to just swap props with your friends until you find the one that works best on your model.
