ORIGINAL: YLF
The temp at max rpm is around 610- 620.
Did your 11lb JJ1400 create more thrust after clearing the plugged needles? How much?
Mike
Mike
After sorting the needles and taking care on the rebuild it was reading just over 12lbs taken while in a model on a paved area. The scales were digital, considering the turbine the second time was shunting the model with 1/2 gal fuel and gear on board it was an OK result, though not to GTBA standards. Can you confirm the outer dia of your compressor (at the inlet) is a nominal 43mm with 12 blades i.e the latest version for the JJ1400.
Paul
