You REALLY NEED to get the entire manual
http://www.futaba-rc.com/manuals/4ex-manual.pdf but I'll try to post bits of it here if I can.
To reverse a servo-
1- Enter programming mode. Use mode key to select "reverse" function
2- use select key to select channel you wish to change
3- push data input lever up or dn to change direction of servo to desired direction
4- use select key to go to next channel to change or exit programming mode
enter or leave programming mode by pressing "mode" and "select" keys simultaneously and holding for about one second.
Set end points as above but choose "EPA" mode.
1- select channel to adjust EPA of
2- Move control stick fully to one end of travel in direction wished to be changed and hold if needed.
3- Use data input lever up/dn to change value to desired amount. Do not overdo this without checking result, you can always go back and do more.
4- Move control stick in other direction if desired to change other end EPA also and use input lever to adjust.
5- Each end of each channel may be adjusted if desired/needed. Be SURE before doing this that you have made all mechanical adjustments that you can first.
6- Exit programming mode
This only effects the plane for the memory position you are working with, not the others.
Now download the rest of the manual.
