basic flight
Ok, Happy new year everybody..late albeit, but hey I got R/C for Christmas..been busy ya know... I've pretty much mastered the 2 channel so-called "trainers". Now I'm ready for some 3 or 4 channel fun. I've narrowed the purchase down to two planes: the Aerobird Challenger, or the Begin-Air. One is 3ch and the other 4ch. I'd like some clarification, on wehther or not I have this correct: In both the 3 and 4 ch configs, I would use the throttle to gain airspeed, and thus, altitude, right? Then the elevator will change the pitch of the aircraft to get it pointed where I want (up or down). In a 3 ch config, I use the rudder to turn the plane, then add elevator to keep the altitude up since I lose some in the turns, right? How does the throttle play into the turns?? In a 4ch config, airspeed/ altitude will work pretty much the same as a 3ch right?? In turns however, the ailerons bank the ship, then the elevator turns it in the general direction, and the rudder is used sparingly to "smooth out the turn" Right?? Or do I use the rudder to turn, the ailerons to smooth, and the elevator in the same fashion? Any help here would probably save me a bit of re-building time. Assume that I live on a dessert island here...no instruction sans what I read here...
