RE: Fast Idle
Have you tried adjusting your idle screw? It adjusts the minimum opening of your carburetor. The larger the opening, the higher the idle, and vice versa. Also, your low speed needle can affect the idle. The leaner it is, the higher the idle, and vice versa.
