RCU Forums - View Single Post - FunFactor BONE STOCK NT-16 Blown after only 1 gallon (UPDATE)
Old 01-12-2006 | 11:36 PM
BootMachine
Default RE: FunFactor BONE STOCK NT-16 Blown after only 1 gallon
For now I just want to stick to the stock engine because the piston and sleeve are perfect with hardly any use. When they wear out I will upgrade the engine.
Upon closer inspection it appears that the rod broke due to a defect. The groove milled down one side to reduce weight was cut too long and came too close to the bottom. The crack starts right where the groove ends.
If I show CEN the part and prove that the ATX is only a few weeks old do you guys think they will send me a new connecting rod?
