Layed down the fuselage side that already had the doubler mounted on it to make sure I was gluing up the other fuselage side correctly. I left the weight on for a few minutes and then pulled it off to wipe excess glue and then put the boards and weight back on. Pulled the tube and dowel a little while later. Will dry overnight.
I had to let my wing dry last night but still wanted to work on my plane. That's why I started working to get the fuselage put together.
