RE: SM F15 elevator servo chatter
Anurag,
All of above are very good suggestions to check. The Skymaster F-15 elevator don't require balance. I believe already have hundreds F-15 flight as not balance and no the issue as you describe. The problem you have is not normal, you should check it before fly.
