RE: NexSTAR Bubbles in Fuel Line
My Nexstart has the exact same problem. I will follow these tips and report back as well. Last night I spent an hour ballancing two props. I broke out the nail polish and sand paper. I aslo did the underwater test and put as much pressure in the tank as I could...no leaks. I added some more foam around the tank, but if that still does not work, I will end up gouging out the rubber-coated balsa supporting the tank and wrap it in foam like a freak! I'm really supprised to see how many Nexstars have this issue.
