RCU Forums - View Single Post - DA 50 midrange setup
Old 01-13-2006 | 10:40 AM
famousdave
My Feedback: (61)
Default RE: DA 50 midrange setup
ORIGINAL: RCFREEK
i use 2 stroke motorcycle oil, which, i guess is not synthetic. Is that ok? ill try out the needle setting as u recommend and let u know asap. thanks
There are two kinds of two stroke motorcycle oil - synthetic and non-synthetic. Non-Synthetic is distilled from raw crude oil (i.e. its a direct product of crude oil) Synthetic is synthesized from the components of crude oil (amongst other things).
If you have limited access to oils, a good two stroke motorcycle oil of either type is fine. I know many people who run synthetic oil in their engines from day one and they work and last just as long as those who use non-synthetic first and switch.
Bottom line - if you are using a good oil (i.e. Motorex, Bel-Ray, or other name brands) you will be fine, just make sure you mix at the recommended ratio on the bottle. Non -synthetics 32:1 and Sythetics vary between 32:1 and 100:1 so you have to be careful.
DP
